1/4" SA36 plate can be rolled for shell of tank
I have need a help,sir. we have a tank to build under ASME code, however the tank pressure is under 15psi. it will be have leak test at 10KPA/1.5psig. The question is the shell will be use SA36 rolled plate 1/4"THK. I read UCS79, but I am still not sure it is ok to use it.
RE: 1/4" SA36 plate can be rolled for shell of tank
