H2O enviroment
H2O enviroment
I would like to create a COSMOS enviroment detailing the specifics of water - and how it reacts to a body in that water. Is it possible to simply identify all of the water's forces, or is there a package that more easily accomplishes my task?
RE: H2O enviroment
You will need to supply the number for density for the fluid you are using. For water there are slightly different numbers for density of freash water versus sea water.
good luck-
-MB
