Projected curve in sketcher
I would like to ask, if it is possible to create the associative projected curve in sketcher ( for example edge or previous sketch) and modify it, but keep it associative. Or any other solution how to do that...
Vit
RE: Projected curve in sketcher
What type of modification would you like to do? More importantly, what end result are you trying to achieve? If you give more information on your end goal we may be able to help with what you describe, or point you in a different direction that will still get what you want.
In NX 6 we are adding an 'Associative Trim' function intended to work with Projected and Intersection curves included in the Sketch.  This will allow you to edit the 'effective' portion of the projected/intersection curves while preserving the curve and it's associative links to the original curve/edge/face.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
That's great to hear!  We have been asking for an associative trim for a while now.
Coming from Pro/E, most of our users do not appreciate the ability to 'haystack' through the sketch.
Ed
