Spot test for H2S
Spot test for H2S
Spot test for H2S
Please provide spot test procedure/solution for detection of trace amounts of hydrogen sulphide on a steel surface and any reference literature in this regard.
RE: Spot test for H2S
If you want just a qualitative test you can use lead acetate tests strips available at any laboratory supply house.
http://www.opticsplanet.net/precision-laboratories-ph-test-papers-precision-laboratories-175.html
More meaningful quantitative results can be made using Draeger Tubes.
http://buydraegertubes.com/index.asp?PageAction=VIEWCATS&Category=10
If you want to have a continuous monitoring system check with your local utility and see which meter they are using.
