DraftDocument PrintOut Sub. How can I print a specific sheet.
This is my first post.
I have been programing diferent tools using VBA in Excel that work with SE.
Now I am trying to print a specific sheet of a draft document.
I open the draft document, detect the sheets size and orientation but I can't print out only a specific sheet.
The function I am using is:
Sub PrintOut([Printer], [NumCopies], [Orientation], [PaperSize], [Scale], [PrintToFile], [OutputFileName], [PrintRange], [Sheets], [ColorAsBlack], [Collate])
For example whith an open document:
Set objApp = GetObject(, "SolidEdge.Application")
Set objDoc = Nothing
Set objDoc = objApp.Documents.Open(CStr(Trim(celda.Value)))
lPaperSize = objDoc.ActiveSheet.SheetSetup.SheetSizeOption
lPaperOrient = 1
Call objDoc.PrintOut(Orientation:=lPaperOrient, ColorAsBlack:=True, PaperSize:=lPaperSize)
The document have 3 pages or sheets and I want to print only sheet 1 (call sheet "Sheet1") but I can't.
I have tried lots of posibilities but I can't do it.
I need some help.
RE: DraftDocument PrintOut Sub. How can I print a specific sheet.
before the RpintOut use this:
    objDoc.Sections.WorkingSection.Sheets.Item(" your sheet name here ").Activate
Note: the name of the sheet must be typed exactly as found on the tab.
HTH
dy
I did this:
objDoc.Sections.WorkingSection.Sheets.Item("Hoja1").Activate
Call objDoc.PrintOut(Orientation:=lPaperOrient, ColorAsBlack:=True, PaperSize:=lPaperSize, Scale:=1#)
But it still printing all pages of the document.
Do you have another one?
thenks
may I point out that the PrintOut method also has a PrintRange
argument which can be given as:
igPrintSelected  = last active sheet
igPrintAll = all sheets
igPrintSpecified =  a range of sheets (i.e 2 to 5 ...)
dy
I can not make it work. Could you please give me a complete example.
Thank you very much.
MS
    Set oApp = GetObject(, "SolidEdge.Application")
    Set oDraft = oApp.ActiveDocument
    Call oDraft.Sections.WorkingSection.Sheets.Item("Connector 3 complete").Activate
    Call oDraft.PrintOut(Printer:="Adobe PDF", Orientation:=vbPRORLandscape, PaperSize:=vbPRPSA3, PrintRange:=igPrintSelected)
Note: lPaperSize = objDoc.ActiveSheet.SheetSetup.SheetSizeOption
will give you SE's paper size but needed is the papersize constant for the
Printer. See also the sample Batch program within C:\...\Custom
These are standard up to at most A3
A4  = vbPRPSA4 = 9  (SE  SheetSizeOption = igIsoA4Tall =28)
A3  = vbPRPSA3 = 8  (SE  SheetSizeOption = igIsoA3Wide = 31)
A2  = 66 (but this may vary from printer to printer)
         (SE SheetSizeOption = igIsoA2Wide = 33
dy
I am very gratefull, it is working now.
Please if you need help in other topics let me know.
MS
you're welcome. To obtain the papersize constants for formats
that are not enumerated you may use the program PaperSizeConstants
(see link below)
dy
