How To Get Dashed Lines From Model Space Into Drawing?
I imported an IGES file into catia. I changes the lines I needed to be dashed in model space. When I then add the view to a drawing...those lines come in solid?? any suggestions?
Ryan Hill
Design Engineer
bestCADsolutions, Inc.
RE: How To Get Dashed Lines From Model Space Into Drawing?
Give to dashed lines a color in model space, go in drafting workbench and check 3D Colors in the view properties (this will color your dashed lines), advance search - workbench drafting - Generated Item - Attribute - Color from Element - select them and set what kind of properties you want (linetype, color, width....).
Fernando
Whoever makes catia...I dont know. Maybe they did it so that your average Joe will give up and then they can charge more. It's so deep@!
Thanks again!
Ryan Hill
Design Engineer
Fernando
