Multiple Decals in Assemblies
Good afternoon, I am using SW2008sp2.1 and I have an assembly with 2 configurations and in the first configuration I want to place a cylinder decal and in the second I want it hidden. I have tried using This configuration and it appears in both configurations and I have also tried using Specific configuration, but after changing configurations, the decal is no longer there. and so when you go back to the first configuration there is no decal any more. If I use all configurations, the same decal appears in a similar assembly as well. Any suggestions to get this to work will be deeply appreciated. Thank you in advance.
RE: Multiple Decals in Assemblies
