pelletizing waste
pelletizing waste
Does anyone have experience with drying and pelletizing animal waste? What type of value as fertilizer would this have? I suppose you run it through a screw press to get the water out and then pelletize and dry? Please advise.
RE: pelletizing waste
I can't recall its fertilzer rating'. But I suspect a sample provided to a lab would get you results of its component values.
Here is something for you to think about:
http://www.cowpots.com/
Orenda
This aside, there are several small organic fertilizer granulation plants in operation in the US. These typically use Chicken manure as a main ingredient and add other natural ingredients to raise the nutrient content. This fertilizer obtains a premium amount per nutrient because it is organic and it typically contains many micronutrients compared to chemical fertilizer.
This granulation process is preferred because it produces a better quality product and allows more ingredients to be successfully added. It is typically produced in greens grade, turf grade, and agricultural grade, although golf course varieties are usually worth the most.
Years ago larger chicken farmers (Purdue is the main one I am thinking of) did install pelletizer process plants because they were producing such a large excess of hen wastes. I do not believe the manufacturer of these plants is still in business as it was only made profitale for environmental reasons (Purdue was having trouble getting rid of raw waste).
As for the organic granulation process look at www.ajsackett.com
Best,
DB
