coolant/ hydraulic oil waste containment/ storage unit
I am looking for some advice on waste container storage unit design. I work for a earth/ sitework and utilities contractor and was contacted by a firm who wishes to have a storage shed for the above purpose. I was told they will be dealing with coolant and hydraulic oils, and possibly pressure washing machine parts. I am aware they should probably be contacting an environmental firm and doing the whole DHEC (South Carolina)review and I don't plan on any environmental or approval process violations, but I was wondering if anyone can point me to a basic design drawing for this type of set-up. I am thinking of tanks from Myers waste oil storage system inside a containment dike accounting for 25 yr storm. What sort of design could handle where they would pressure wash into a drain? Could I sump (positive displacemnt pump)it into a water containment/recycling(separater) tank inside a fenced area? What firms make rounds to collect and dispose of captured solids or fluids. I know this is a tough question but that's why I'm in design/ construction- it never gets boring. Any help would be much appreciated.
RE: coolant/ hydraulic oil waste containment/ storage unit
http://www.wbdg.org/ccb/browse_org.php?o=70
You can probably find some documents for refueling or fuel storage that may be useful, Spec Section 33.
And don't forget to design for flammable liquids.
Stonecold
Regarding the design, if secondary containment is required for the tanks it will need to contain a minimum of 110% of the tank volume plus rainwater. Check the local regs for the storm event. For this reason, some tanks and containment areas are often covered. It kind of an economic balance between cost of constructing the roof and the secondary containment size. Lots of times, it is cheaper, safer and easier to install ASTs with built in secondary containment (see ConVaults, for an example, though I prefer metal tanks).
As for the pressure wash area, I would highly recommend adding a roof for this area and keep it separate from the ASTs. Once they pressure wash some nasty greasy part in the area, any water (i.e. rainwater) that comes into contact with the floor and sidewalls will need to be properly disposed of. Think of the cost of water disposal every time it rains even if they are not using the pressure washer. If the parts are small, there are pre-fab’ part washer units that contain all the rinse waters and work really well. If the parts are large consider using a suspended metal grate floor to stand on that way you can really slope the floor beneath to drain to a sump. Plus a grate floor will be safer to stand on. Most likely you will not need to install a pump in the sump, just provide access for vacuum truck which is how most of these kinds of water are collected. Also ask the client if they plan to use any solvents, you will need to check the chemical compatibility with you tanks and construction materials.
Finally MAKE SURE YOU SEAL THE FLOOR and SUMP!! I cannot tell you how many sites I have been to that floor and/or sump was not sealed and the soils and groundwater beneath the site were contaminated due to poor construction and/or design.
Sorry if I ramble on to much, I am new to the forum.
