Comparison on BS8110 & ACI 318
Where can I look for the information on the comparison between BS8110 Part 1 and ACI 318 (95)?
Comparison on BS8110 & ACI 318Comparison on BS8110 & ACI 318(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Comparison on BS8110 & ACI 318
What do you ewant to compare them for?
The codes are completely different in approach in many areas of design. Buy a copy of the codes and read them. This is the only way if you want to use either. It is the only responsible approach for a design engineer.
maybe this helps you:
structuralengineer
Issue 22-2000 (21 Nov 2000)
Limits on load carrying capacity of flat slabs
Synopsis
Design of flat slabs is usually based on separate considerations of flexure and shear, with empirical rules similar to those used in design of beams and continuous
slabs. Additionally, shear capacity of a flat slab has to account for its distinctive mode of failure known as ‘punching failure’ or breaking away of a portion
surrounding the column from the rest of the slab. Provision against such failure is often the critical design requirement for flat slabs with or without openings
adjacent to the columns. While links are normally provided to enhance the punching shear capacity, the current Codes of Practice stipulate limits on the loadcarrying
capacity of flat slabs. Such limits govern the thickness of the slab and, therefore, have a direct influence on economy of construction. This paper examines the limits
on loadcarrying capacity of flat slabs supported on internal and rectangular columns, which are given in BS 8110 and Eurocode EC 2, with the help of tests on slab
specimens with and without openings.
S. B. Desai, OBE, BE, PhD, CEng, FIStructE formerly, DETR
Keywords: flat slabs, design, BS 8110, Eurocode 2, comparing, shear, load tests, research
http://www.istructe.org.uk/thestructuralengineer/files/synopsis.pdf
