Curved Concrete Stairs
Has anyone any experiance in designing curved concrete stairs (without using finite element analysis software). A point in the right direction would be appreciated especially UK codes.
Thanks.
Thanks.
RE: Curved Concrete Stairs
Dik
I always like making stairs look like they have no visible means of support!
One of the two toughest things I've ever designed...
Dik
Good stuff. Did you re-analyse the stair with the help of computer program, and see how close your calculation was?
Very good engineering.
Again well done.
Did you look at Reynolds & Steedman Handbook? Also the published another book on BS 8110 Code
These two books would give you a solution to your prblem.
HTS
Our firm is looking for some software for 2-way slabs and other more complicated concrete design.
Any suggestions?
Quite curious after these magnificent stairs!
(I've walked down them, and admired them, prior to seeing them here... Would give almost anything to see a scan of the structural details!)
Cheers,
YS
B.Eng (Carleton)
Working in New Zealand, thinking of my snow covered home...
Dik
http://hometown.aol.com/lorgallego/stairs.jpg
That link didn't work for me, but I have it on my list to see if I ever get through Santa Fe. Thanks.
