pdmworks problem
pdmworks problem
pdmworks problem
I've taken ownership of a part, checked it out, modified it and now I want to check it back in.
it proceeds to check it in then stops with
Vault Error 102:  You have no permissions to change the document properties.
I'm at a loss as to how to fix this
pdmwadmin does not have this problem.
RE: pdmworks problem
It means you don't have read/write permissions to the file. You need to contact you vault administrator and get that fixed.
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
jazgeek,
Use SolidWorks Explorer to search for the part. Do you have ownership? Is the part number shown in red? If you have ownership and the part is not red, then have the administrator stop and restart the pdmwService on the server. Then try to check it in again. If you cannot then your VAR needs to be called.
Bradley
SolidWorks Pro 2008 x64 SP3.0
PDMWorks Workgroup, Dell XPS Intel(R) Pentium(R) D CPU
3.00 GHz, 5 GB RAM, Virtual memory 12577 MB, nVidia 3400
e-mail is Lotus Notes
No, seriously, from the kb:
Question: The Vault error 102 is generated when checking documents into the vault, why?
Answer: Error 102 can be encountered when Lifecycle is enabled in the PDMWorks VaultAdmin and the 'Control document access using status' option is checked. The user that that does not have Read/Write permissions will see the error 102 - You have no permission to change document properties - when checking-in documents, and the check-in operation will be aborted. You will need to contact your PDMWorks administrator and request R/W permissions for a certain lifecycle status.
Jeff Mirisola, CSWP
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
