Flatness at MMC?
Flatness at MMC?
Hello everyone,
I am new on the eng-tips forums. While I am no expert in applying GD&T, I have taken some courses and use Y14.5M standard and other handbooks as reference.
I have recently picked up the "Dimensioning and Tolerancing Handbook" by Paul Drake... highly recommended! I am struggling to come to terms with an example given in the book. On page 5-31, in the GD&T chapter, Figure 5-27, the example shows a washer with .032+/-.002 thickness and a flatness callout of 0.020 at MMC located below the thickness spec (not attached to any surface). I understand what the intent is: Allow warpage greater than the thickness tol. This allows deviation from Rule #1, but is obviously more restrictive than specifying PERFECT FORM AT MMC NOT REQD.
My understanding is that flatness cannot be used with modifiers, such as a tolerance zone, at LMC, at MMC, etc. Is this a mistake in the book? Should straightness have been specified instead? Note that the flatness is not called out for a surface; it is called out for the thickness.
RE: Flatness at MMC?
Powerhound, GDTP T-0419
Production Supervisor
Inventor 2008
Mastercam X2
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
MMC is only used on feature of size and not on surfaces.
Dave D.
www.qmsi.ca
yes, i am looking at a flatness callout. My eyes aren't great, but they're not that bad!
dingy2:
The flatness callout is not attached to a surface. It is floating below the thickness dimension/tol, similar to a feature tolerance of position control.
On page 5-15 of the book, table 5-1, a chart is shown with all of the geometric characteristics (flatness, profile, runout, etc) and their attributes, such as LMC/MMC allowed, basic dim reqd, etc. For flatness, two usage circumstances are shown as being allowed:
1. to control a plane, were you have a leader attached to the surface, no datum references, no LMC/MMC condition allowed.
2. to control a "width-derived median plan", where the control frame can be placed below a feature of size dimension, no datum references, LMC/MMC condition IS ALLOWED.
This flatness usage in some ways does make sense, but in looking at other reference books, such as Alex Krulikowski's "Fundamentals of GD&T", flatness at LMC or MMC is illegal. Is strightness the proper control of this case?
The only other option I can imagine for such a grossly incorrect section on flatness is that the intended explanation of geometric characteristic was straightness as I alluded to in my first post in this thread.
Inventor 2008
Mastercam X2
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
I agree that the Drake book is clearly wrong. The erroneous flatness callout should have been a straightness control. The previously mentioned table 5-15 is clearly also wrong.
After digging deeper, I found figure 3-16 in Krulikowski's book that clearly shows using straightness at MMC to control the warpage of a washer-like part.
That said, I have yet to find this sort of misleading information in anything written by those mentioned by CheckerRon.
Believe it if you need it or leave it if you dare. - Robert Hunter
fteixeira, the text you mention isn't in anticipation of the newer version is it?
KENAT, probably the least qualified checker you'll ever meet...
"Dimensioning and Tolerancing Handbook" by Paul Drake is from 1999, ISBN-0070181314. Any new proposed updates to the standard are obviously not included. I wondering if such flatness usage was ever allowed in the 1973 standard?
By the way, I do have a copy of the Y14.5M-1994 standard. Section 6.4.2.1 is very clear as to the proper usage of flatness. In my OP, I was questioning the usage in the Drake book. I wanted to ask the forum if they agreed, or was I missing something.
I think that the improper flatness usage was an unfortunate mistake in the book.
Obvious question. If straightness modified MMC works, why is the proposed 2008 standard doing it for flatness?
Don't have a copy to check it out, but it sounds redundant.
It is somewhat redundant, one is an axis and the other is a center plane. I do not know why they did it.
Side note: I hear the committee is considering another draft.
Seems like it would be easier to expand the definition of straightness to also include a center plane, for non-circular features (e.g. thin plate or sheet metal) and use MMC vs flatness, which we all view as a planer surface.
But then supposedly, committee members have a broader view the things--we hope.
Another draft huh? I will be retired (again) by the time the next Y14.5 gets released.
The current definition is already expanded to include "centerplanes" for non cylindrical features of size. See section 6.4.1.1.3 of ASME Y14.5M-1994.
Paul
I took a quick look at the straightness secton Friday but that paragraph didn't catch my eye. When I had an application like that, I probably used profile-of-a-surface, but straightness would work too, and apply MMC.
This, however, reinforces the question of why modify flatness to cover such an application in the new standard?
I received an answer from Paul Drake, the editor of the "Dimensioning and Tolerancing Handbook" regarding the discrepenacy in his book (see OP). Paul refered me to section 5.8.4 of the book, where flatness for a width-type feature is discussed. It is clearly stated in the book that flatness form tol of a mid-plane is NOT covered in the Y14.5 standard, and that "where strict adherence to Y14.5 is needed, the "straightness" symbol should be used."
Straightness of a plane seems unsettling. I tend to feel that straightness should be a one-dimensional concept. Straightess of a line surfance-element or axis is easy to grasp, but straightness of a mid-plane? What does that mean? When straightness is applied to a surface (not a FOS), the theoretical element is a straight line, in the plane of the view, with a tolerance zone consitenting of 2 parallel lines. When applied to a diameter FOS, the tol zone is a cylinder. But when applied to a planar FOS, the tol zone is two parallel planes? It seems that the straightness concept is doing triple duty, thereby diluting its definition.
It seems that this point will be discussed in future committee meetings. In the mean time, to be consistent with Y14.5M-1994, I will use the straightness for planar FOS's as defined in the standard.
