Which is Best - AGAIN
Why does the "Which is Best, Solid Works or Solid Edge"
always get loads of hits.
Im using Solid Edge. I have selected. Im in. I got with the program
All I want is a bit of help
from Solid Edge users about USING not comparing.
Come on Guys, all you users who know the SE secrets
answer my posts pleeeeeeeaaaaseee
Surely there must be a FAQ for SE v SW v Catia v UGS v AutoCad
Milkboy
RE: Which is Best - AGAIN
I guess that question applies to many things...
My car is better than your car, my dad is stronger
than yours, I remember when I was using Autocad it was
Autocad vs. Cadkey, I don't bother reading those types
of posts any more because the answer is simple, it's
whatever you like best. but I digress...
If you are using Solid Edge, do you have a valid
maintinence contract? if so you can access the Solid
Edge Newsgroups Hosted by EDS, it is a private newsgroup
accessible to those with valid Maintinence contracts.
Here's where to go: http://bbsnotes.ugs.com/
-Scott
Ill get in touch with myCAD Contact about this
as we are in colab. with EDS / UGS
Milkboy
