product to part
product to part
hi
Is it possbile to keep the colours constant as its was when creating part from product.I use the command to generate catpart from catproduct.
Please suggest me if there is any work around.
Thanks inadvance
Thanks inadvance
RE: product to part
Derek
RE: product to part
The method what ur describing is about step conversion, those settings are ok but what i was intended for is it possible for maintaining colours when converting a product to part without maintaining levels in the structure
RE: product to part
Derek
RE: product to part
1. Open CATProduct
2. Change color of PartBody(s) or GeometricalSet(s) only!
3. Generate CATPart from CATProduct.
Note: If you change color of the "Instances" it will not work!
Hope this helps!
Peter
RE: product to part
RE: product to part
If you do not select Keep colors and attributes on subelements, the whole solid takes the color of the original body.
If you select Keep colors and attributes on subelements, the color you have applied to a face is kept.
RE: product to part
That's the stuff I told you about... you need DF1 license :
Product Data Filtering (we do not have it in production)
