NPT fittings in an AC system?
If you folks were to review a design for a vehicle AC system that included a manifold with NPT connections, what would you say? Seems to me that NPT is a bad choice for moving R-134a, won't it bleed out over time.(even with pipe dope)
Correct me if I'm in error.
thanks
thanks
RE: NPT fittings in an AC system?
Since they are already there, you need to clean them well and coat them with A Loctite product specifically for refrigerant service. It will hold pretty well and can be heated to remove the plug later.
Ken
Ken
KE5DFR
The short answer is someone that has no buisness designing things specified a manifold with NPT connections.
Thanks for your input. Are the manifolds you are referring to "in-line" (ie) constantly presurrized or are you talking gage manifolds for checking the high and low side as a diagnostic tool?
