Get all dimension parameter from assembly
Hi!
I have a big problem. I like get the all dimension parameter of my assembly. (API)
I don't know the name of parameter, therefore I like get the all parameters, and I check the read-only flag of dimension (and set to false, if not...)
I not found any method that read up the parameters of assembly (without name of parameter).
Have you any idea?
ZsZs.
RE: Get all dimension parameter from assembly
I did a Pack'NGo with API functions. (C++ COM technique)
I have some bad equation (and many good too).
I like to change the bad equation to the good. It is very simple.
I attach a picture. The dimension in the purple ellipse are read-only.
My job remove the read-only flag in the assembly.
This parameter in the part isn't read-only.
Before I upgrade the equations, I need to remove the read-only flag from assembly.
The main problem, that the equation refering the part, but it is correct (not read-only).
The dimension of assembly, above one level of part, is read-only.
And I don't know the name of assembly! (I need find without filename.)
I see one possibility: read all dimension of all assembly, and if found some read-only dimension, I remove this flag.
Accordingly, I need a method, that I get the all dimension parameter of a assembly.
I wrote a small program:
IFeature *Feat = NULL, *FeatNext = NULL;
swDoc->IFirstFeature (&Feat);
while(Feat)
    CComBSTR bName("");
    Feat->get_Name(&bName);
    string FeatName = UTIL::BSTR2str(bName);
    CComBSTR bType("");
    Feat->GetTypeName2(&bType);
    string FeatType = UTIL::BSTR2str(bType);
    cout<< "Feature - Name: " << FeatName << " Type: " << FeatType << endl;
    IDispatch *Disp = NULL, *DispNext = NULL;
    Feat->GetFirstDisplayDimension(&Disp);
    while(Disp != NULL)
        IDisplayDimension* swDispDim = NULL;
        Disp->QueryInterface(IID_IDisplayDimension,(void**) &swDispDim);
        IDimension* swDim = NULL;
        swDispDim->GetDimension2(0, &swDim);
        if(swDim != NULL)
            CComBSTR bDimFullName("");
            swDim->get_FullName(&bDimFullName);
            string DimFullName = UTIL::BSTR2str(bDimFullName);
            unsigned short int* x = 0;
            double retval = -1;
            swDim->IGetSystemValue3(swSetValue_InThisConfiguration, 0, &x, &retval);
            string DimValue = UTIL::d2s(retval);
            cout << "\tDimension: " + DimFullName + " = " + DimValue << endl;
        Feat->GetNextDisplayDimension(Disp, &DispNext);
        Disp = DispNext;
    Feat->IGetNextFeature (&FeatNext);
    Feat = FeatNext;
This is working correctly by the parts.
The results:
Feature - Name: Design Binder Type: DocsFolder
Feature - Name: Annotations Type: DetailCabinet
Feature - Name: Lights, Cameras and Scene Type: EnvFolder
Feature - Name: Solid Bodies Type: SolidBodyFolder
Feature - Name: Surface Bodies Type: SurfaceBodyFolder
Feature - Name: Comments Type: CommentsFolder
Feature - Name: Glass Type: MaterialFolder
Feature - Name: Front Plane Type: RefPlane
Feature - Name: Top Plane Type: RefPlane
Feature - Name: Right Plane Type: RefPlane
Feature - Name: Origin Type: OriginProfileFeature
Feature - Name: Sketch1 Type: ProfileFeature
        Dimension: D1@Sketch1@UhK05_JUNS02-2_Mb26_002.Part = 0.69633
        Dimension: D2@Sketch1@UhK05_JUNS02-2_Mb26_002.Part = 0.54448
        Dimension: D3@Sketch1@UhK05_JUNS02-2_Mb26_002.Part = 0.21915
        Dimension: D4@Sketch1@UhK05_JUNS02-2_Mb26_002.Part = 0.48626
        Dimension: D5@Sketch1@UhK05_JUNS02-2_Mb26_002.Part = 0.73
Feature - Name: Extrude-Thin1 Type: ExtruThin
        Dimension: D1@Extrude-Thin1@UhK05_JUNS02-2_Mb26_002.Part = 0.926
        Dimension: D5@Extrude-Thin1@UhK05_JUNS02-2_Mb26_002.Part = 0.005
Feature - Name: Chamfer1 Type: Chamfer
        Dimension: D1@Chamfer1@UhK05_JUNS02-2_Mb26_002.Part = 0.001
        Dimension: D2@Chamfer1@UhK05_JUNS02-2_Mb26_002.Part = 0.785398
Feature - Name: Chamfer2 Type: Chamfer
        Dimension: D1@Chamfer2@UhK05_JUNS02-2_Mb26_002.Part = 0.001
        Dimension: D2@Chamfer2@UhK05_JUNS02-2_Mb26_002.Part = 0.785398
BUT if I scanning a assembly, not found the dimensions:
The result:
Feature - Name: Equations Type: EqnFolder
Feature - Name: Fns1_JUNS02-2_Mb26_1_002-1 Type: Reference
Feature - Name: Fp01_JUNS02-2_Mb26_1_002-1 Type: Reference
Feature - Name: SeK06_JUNS02-2_Mb26_002-3 Type: Reference
Feature - Name: SeK06_JUNS02-2_Mb26_002-2 Type: Reference
Feature - Name: UhK05_JUNS02-2_Mb26_002-1 Type: Reference
Feature - Name: Mates Type: MateGroup
I how access, the dimension parameter in assembly file?
ZsZs.
