How to calculate required valve closure times to prevent surge..
Dear sirs,
I've read lost of really detailed articles about pipeline surge or water hammer.  I am working on project with short lines <2 km. Most less than 300meters,  I want to calculate if there is likely to be a surge problem and if i need to specify slow closing valves.
 Can anyone please point me in the correct direction of a calculation guide.
RE: How to calculate required valve closure times to prevent surge..
300 m could cause surge. The rule of thum is that the closing time of a valve should be more than twice the length divided by the speed of sound in the liquid. But then again what if a valve is almost closed at the steady state flow condition?
Perry has a short primer on the subject.
Best regards
Morten
You have to be more careful with valves patterns that allow almost full flow to continue until they reach about 10% open, then stop all remaining flow from there to 0% open.  A long closing time doesn't do much good with those types of valves.
http://virtualpipeline.spaces.msn.com
"What gets us into trouble is not what we don't know, its what we know for sure" - Mark Twain
