Scissors lift on composite slab
Anyone ever run into trouble with scissors lift (or similar) loading on composite slabs? Do you specify an allowable wheel load or similar in construction docs?
tw
tw
RE: Scissors lift on composite slab
This is considered means and methods and therefore not part of the building design. If it doesnt work then you just need to provide enough shoring so that it does.
refer:
http://www.njb-united.com/usd/ddds/data33.pdf
Check the floor or shore it as suggested.
If you do a calc on this ask them for the specific scissor lift that they plan to use so that it can be allowed for.
It also needs to be ensured that the stacking of materials is not detrimental to the slab also.
