Help on StormCAD
Help on StormCAD
Hi guys:
I'm not sure is this is repeat post or not. I am new to the StormCAD program, and I'm a old school to do drain pipe design(use excel most of the time) I have just started to just the porgram. And, I've been told that it can use rational method and Hazen-Williams Equation combine to do the backflow analysis on stormCAD itself. Can someone show me the processdure how to do it in stormCAD?
Thank you
Thank you
RE: Help on StormCAD
I would recommend working through an example/tutorial first. I have not used Stormcad in some time but I remember doing just that when I first learned. If memory serves me correctly, you will enter the data on each inlet you place. Check out the online help and/or the manual.
I wish I could be more help.
The Rational Method too has any limitations. As a ruling pen, drafting linen, slide rule era engineer, I wouldn't use either.
good luck
For storm water, the rational method is used to compute runoff. You'd use it to get flows to each inlet. From there, I believe you could use the H-Z equation to determine headloss and other flow characteristics in the system. There is an option in StormCAD to select your analysis method.
But usually for storm water systems, Manning's equation is preferred, because of the reasons RWF mentioned. For a small system (roof drains perhaps), H-Z should work fine.
Thank you for you answer. I am doing a big drainage piping design, and yes I need to see the headloss and other flow characteristics in the system. So where is the selection in StormCAD that I can select the different anaylsis method?
