Static grounding of process vessels inside building
I do not have access to API RP2003 and am wondering if anyone knows if it is acceptable to have vessels housed inside a building grounded through the building's skid. Two corners of the building have ground cables and each vessel is either welded or bolted to the skid. Any info appreciated.
RE: Static grounding of process vessels inside building
You will probably get an answer from the following fora...
forum242: IEEE (electrical) Code Issues
forum248: Electrical/Electronic engineering other topics
forum238: Electric power engineering
