Schrader Fittings w/ R-410a
What are your opinions of using Schrader fittings on a R-410a system in general and more specifically for a place to mount pressure switches vs brazing. The idea is - in a tight package, it is easier to replace a defective pressure switch that's fitted to a Schrader fitting than tear the unit apart such that one can un-braze and re-braze the switch.
Any advice would be much appreciated.
Thanks!
Bill
Thanks!
Bill
RE: Schrader Fittings w/ R-410a
