C30+ in the Hysys 2006
Hi all!
In the Aspen Hysys 2006, the component's characterization only has to C30, How can i add components C31-C36? can i user hypothetical component, and how?
thank you!
RE: C30+ in the Hysys 2006
Hypothetical components are created in the basis manager. There is a tab named "Hypotheticals". Create a blank group and add the hypo's. There is a minimum amount of information required (Typically boiling point and liquid density)needed. Hysys can estimate the remaining properties. However the more information you can give it, the better the estimates will be. The problem is to get the properties of the C31 to C36 components.
Another way to deal with the uncertainty is to use the oil manager and let it calculate some hypotheticals for you.
--Mike--
You got to have a basic understanding of thermodynamics and properties model to do this. But apart from this mikeclay has it right. The oil manager is an extra option that cost a lot of $$ and actually requires more input. It depends on the data that you have.
The hypo components could be with a lower/different mol weight than the components in the component list since these represents a sort of n-alkane representation whereas the hypo components are representing a host of different molecules with average properties and interactions (a somewhat simplified explanation i know)
Best regards
Morten
To broaden a little: If the components has been given to you e.g. from reservoir engineering they may say
C9
C15
C20
But this is normally NOT n-alkens but means the average weight for this pseudocomponent equals that of C15
Ther companies may write:
C8-C12
C12-C17
C18-C25
Best regards
Morten
