Colored lines indetail drawings
I have a detail drawing with views that need different colored lines that are different from the model. Is there away that I cand change the color of lines in a drawing without affecting the model.
Danoo
Danoo
RE: Colored lines indetail drawings
this procedure will change the entire component color however where the component shares common edges they will still display white.
If you get issues with the drawing view lines interfering with your colinear sketched lines, you can hide them in the drawing view using View>Drawing Display>Edge Display.
Jon Reynolds
