imprinting surfaces using multiple contours
Using split line I can do this (split surface for cosmos analysis purposes) but I can only do it with one contour. In this case I am playing heat sources on a board, and have multiple sources and do not want to create multiple sketches if possible. Any ideas?
RE: imprinting surfaces using multiple contours
I guess Ill see if the above REALLY worked when I start applying loads!
1) Extrude your multiple-contour sketch as a surface body
2) Insert, Curve, Split Line
3) Select "Intersection" as the type of split
4) Select the relevant surface bodies you wish to use to split the faces of interest. It helps to use the flyout feature tree for this - you could also set a selection filter
5) Select the face(s) you wish to split
6) Hide the extruded surface bodies to see the split face(s). You can also delete the surface bodies if you will no longer need them.
thanks.
