START UP ANOTHER PROGRAM FROM WITHIN ?
Is it possible to start another existing '.exe' file from within a running visual basic executible ?
If so, can you tell me the relevant commands ?
Cheers.
Cheers.
RE: START UP ANOTHER PROGRAM FROM WITHIN ?
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
A further question ... is it possible having started up that second program, to insert a word in a text box in the second program ?
For your second question use sendkeys
I can start another program, say called 'name' from within a running .exe with shell(name.exe) and write to it using SendKeys "words", for example. But there seems no control over exactly where the sendkeys statement places "words" in 'name.exe'. Is there some way to identify, say text1.text in the 'name.exe', as a destination for "word" ?
Alternatively use any keyboard shortcuts existing in the second program from SendKeys (another possibility is the correct number of tabs from sendkeys)
