Cut - sweep (loft) - with 2 guidelines
Hello ,
I want to cut away a section that have to follow 2 different guidelines (2x a 3dsketch).
How can i make this possible ?
Do i define a several sections en use a cutloft several times ?
See the picture attached :
I have to cut away the untherside of the U-form following a outerguideline and a innerguideline
Greetings
michael
Greetings
michael
RE: Cut - sweep (loft) - with 2 guidelines
I wil try this also
But I did the following thing (maybe to complex):
I create 4 skechtes : 2 in parralel face + 2 in the corners.
I use the cut loft to connect them wit the 2 guidecurves.
At the underside i connect them with a straigt line also
