Water Source Heat Pump Loop Temperature
Is there a good way to calculate the lowest possible temperature for loop heating while maintaining enough heat to prevent appliance lock-out...or is trial and error the best method?
Would the same formula work for cooling mode?
thanks, Tom
RE: Water Source Heat Pump Loop Temperature
Geothermal type units may be better suited for low water temperature applications for heating purposes.
Good luck Tom......
ontheqt...
thanks for pointing my nose in the direction of COP.
That's what I was looking for and oddly...it never occured to me.
Tom
