Automatic Line Divide at Story Level
Hi guys, when I draw a diagnal member such as a bracer or a long cord in a truss in Etabs, very so often it goes through more than one storey levels defined. The annoying thing about it is Etabs sometimes (not always) automatically divides the line at the storey levels. It causes troubles, for example, when I try to sub-divide this line into segements. I tried to use the "Join Lines" function and it did not work. All the "Splice Point" in the Story Data were turned off. Is there any way to avoid this automatic line divide? Thanks in advance.
RE: Automatic Line Divide at Story Level
