Creat a block from a part
We have a label that is a part. This label gets put into every Solidworks drawing we create for a product which is its on individual assembly. However we have noticed lately that this assembly is taking a long time to load. We have come to the conclusion that this label is linking all our assemblies and drawings and is the reason everything is taking a long time to load. My solution is to take the label and turn it into a block for our assemblers to use as reference. But I have no idea on how to turn a part into a block. Does anyone know how to do this??? Thanks in advance!
Bernie
Bernie
Berndog
SolidWorks 2007 SP4.0
Windows XP Pro SP2, Pentium4 3.00GHz
2GB RAM, Nvidia Quadro FX 3450/4000 SDI
RE: Creat a block from a part
Do you want it as a block to add into a drawing, or the assy?
If you want it as a part still in the assy, save it as a dumb solid (parasolid).
Chris
SolidWorks/PDMWorks 08 2.0
AutoCAD 06/08
ctopher's home (updated 10-07-07)
Berndog
If the label is only placed into a 2D drawing (not the 3D model) why use a 3D part? Could you add the label as text into the sheet format?
Is the label just text in a sketch, or is it an emboss/deboss/scribe on a surface or solid?
How many times is the label used in a typical assy?
Are you using single sheet or multi-sheet drawings?
I doubt it is the label causing the slowdown, but you could quickly check by suppressing all its features in the FM tree and resaving. Then see how long the assy takes to open.
If the assy is growing, it is probably the typical SW/Windows bloat causing the slowdown. Do you use EcoSqueeze or Unfrag?
