difference between aluminum casting alloy 319 and 333
I know the two alloys are used for permanent mold castings but not quite sure the difference between the two in terms of castability (foundry preference), casting cost, quality and so on. Appreciate if you could kindly cast some lights on this.
YYS
YYS
RE: difference between aluminum casting alloy 319 and 333
Quality is dependent on the individual foundry. Availabilty of the 333 might be somewhat less than the 319, as 333 is derived from Precedent 71A, a proprietary alloy.
Thank you.
