Adhesion of Water based UV coatings on tin plate
I'm trying to coat tin plate with Water based UV coatings. I have a big problem with adhesion of my coating on substrate. Do you have an idea of what can i use as surface treatment (actually only dipping in acetone) or as additive to improve my adhesion?
RE: Adhesion of Water based UV coatings on tin plate
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
