Structural Analysis Catia V5R16 SP08
I am trying to analize the flex of a plate under its own weight when supported in all four corners. How is this done, as it will output nothing unless you put a force on top of the plate. Surely this can't be right???? Any ideas??
Thanks in advance.
Thanks in advance.
RE: Structural Analysis Catia V5R16 SP08
Like itsmyjob stated you need gravity and that is gravitational acceleration
Density is not enough. Density and Volume give you Mass, Mass and gravity give you weight.
