Catia V4 drawing to dxf
Hi
I am trying to do a save as on a Catia V4 drawing to a dxf but the resulting dxf file is coming without any text, can you please help?
RE: Catia V4 drawing to dxf
1.) Plot to a HPGL file. (this will generate a catout.hpgl)
2.) on a PC convert HPGL to DXF using a converter that can be downloaded here http://www.noliturbare.com/index.php
If you need a HPGL plotter config file, let me know.
Are you saving directly from v4 with CATDXF command or are you opening in v5 and save as dxf ?
Fernando
I am creating the dxf directly from the V4.
I will try the hpgl option as rickyt suggested.
Thanks for your replies.
