Modeling epoxy
Modeling epoxy
Modeling epoxy
Im modeling up an assembly where a capacitor is epoxied in a housing using 2007.  Is there a simple way to create the "epoxy" in the void between the housing and the capacitor as a model.  I would like to show this for visual appeal. Thanks for your feedback.
RE: Modeling epoxy
So the epoxy is a potting compound?  (I'm surprised it needs to be modeled, but the model will tell you the true volume if you need it.)
With this sort of thing, I use the Cavity feature within the context of the assembly.  Check it out in Help if you're not familiar with it.  Should work great.
Jeff Mowry
www.industrialdesignhaus.com
What did you dream?  It's all right--we told you what to dream.
    --Pink Floyd, Welcome to the Machine
RE: Modeling epoxy
Yup, I agree. use a Cavity feature.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
RE: Modeling epoxy
Yup it is the potting compound. So I created the cavity "in context" utilizing the two parts in the assembly.  The cavity was created, however in don't see anything....what am i not doing right?  Thanks
RE: Modeling epoxy
1. Create a base part that is your epoxy.
2. Insert that into the assy.
3. Create the cavity feature by selecting parts that will be embedded.
RE: Modeling epoxy
Worked great...thanks guys
RE: Modeling epoxy
My material database has a few materials for epoxies, if you need them.
Chris
SolidWorks/PDMWorks 08 2.0
AutoCAD 06/08
ctopher's home (updated 10-07-07)
RE: Modeling epoxy
And it is a fine database too.
RE: Modeling epoxy
Thanks. blush
Chris
AutoCAD 06/08
RE: Modeling epoxy
you wouldn't have a suggestion for an epoxy with excellent thermal conductivity would you.
RE: Modeling epoxy
A Google for thermally conductive epoxy yields oodles of hits.
cheers
