testing for sheet piles
I am doing some research for sheet pile wall design with anchors/tie backs attached to a deadman that will hold back a slope on the verge of failure. What sort of parameters are needed to design a sheet wall and what lab testing could be run to obtain these parameters? The anchors are planned to go under a road every couple feet thru sand or clay. Thank you.
RE: testing for sheet piles
http://pz27.pilebuckinternational.com/
http://www.vulcanhammer.net
http://www.vulcanhammer.info
