Design (Technical) Specifications for Ground Water Reservoir
Dear friends,
It would be highly appreciated if help me to find a specification about "Reinforced Ground Water Reservoir", any e file or useful internet site...
thanks a lot
RE: Design (Technical) Specifications for Ground Water Reservoir
You might also try The Construction Specifications Institute.
Your question would be easier to answer if you explained what a "Reinforced Groundwater Reservoir" is. Is this a reinforced concrete tank which is buried in the ground ? Is it a hole in the ground which is somehow reinforced ? Is it a structure built on the ground surface which happens to contain groundwater ?
good luck
I agree with RWF7437 - it depends on what type of reservoir.  In some parts of my country, a reservoir is an above ground steel tank (sometimes conc or PSC).  In other parts, a reservoir is an excavated basin in soil, & lined with a layer of concrete (usually 150 mm thick).  Depths from 10 to 15 m.
All of our 'reservoirs' are also roofed - up to 50,000 m2.
