Using Assembly Scenes In Drafting
Hi All,
Is there a way to use "scenes" created in assemblies in drafting? Some people lock views in drafting but I don't like the idea of possibly having non current views.
I have heard overload properties in drafting should help but I don't understand how it works. Any tips?
petman aka thixoguy
RE: Using Assembly Scenes In Drafting
Yes.  When creating the view, pick the Scene from the Tree before selecting any geometry on the screen.
Thank you kindly, Catiajim
Hi all,
Scenes are usefull on drawing, I use it to show diffrent states of a suspension assembly. The only problem I find is that you can not, or I did not find the way so far, add a new part in an already created scene. I think replace work, but if you have no part to replace, nothing can be done.
Have anyone found a trick to add a part in an already created scene and the dwg will update ?
Myriam
