autocad templates alway end on wrong side
Is there a way to import autocad template on the correct side of a drawing. It alway puts it on the editable side, then i have to cut, edit sheet format, and paste it into the other side of the drawing. Problem is it never keeps the correct position after you cut and paste. Is there a way for it to import on the correct side???
thanks a million,
Matthew
thanks a million,
Matthew
RE: autocad templates alway end on wrong side
