penetration on CMU wall
I have some 16" pipes penetrating 8" block wall. do you guys know any special details to seal the wall? I am thinking just let the mason fill the void with grout. thanks.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: penetration on CMU wall
Is the wall fire rated?
If the pipe does not deflect at the wall (hard joint), but deflects away from the wall (due to flexible roof support) will it place undo stress on the pipe?
If the pipe thru the wall is grouted solid into the wall, it will not deflect. This is where the incompatibility comes from and can cause a pipe to break if severe enough.
