O-ring gland design
O-ring gland design
O-ring gland design
I have a question on designing a floating pneumatic piston ring seal design. I am using the Parker O-ring handbook as a guide. My question is: using a 2-009 o-ring the hand book calls out a .165" groove dia. The I.D. of a 2-009 o-ring is .208. It seems to me that leave too much room for o-ring compression, I won't get a good seal, or am I doing something wrong?
RE: O-ring gland design
Hm.  My old ('01) edition lists a dynamic piston seal groove diameter for a 2-009 O-ring as 0.233 (opposite side of ring mates to cylinder bore at .343.)
Dunno where you get .165 ?
I was using the 5-3 design table for floating pneumatic piston.
When the o-ring is installed, it fits loose (hence floating) until it is squeezed by the bore, .309".  The o-ring OD = the ID + 2*w.  .208 + .140 = .348  This is an OD fit gland rather than an ID fit gland.
Ted
Thanks Ted, just wanted to get a second opinion before I start cutting metal.
