Problems ending out of an AutoCAD dwg.
I've noticed a time or two that when I'm working with an AutoCAD drawing, where I have generated a Wblock from the drawing file, and I go to end out of the drawing AutoCAD "quits out" rather then "ends out"! When AutoCAD "quits out" it does NOT save the drawing or any changes I've made! BUT it doesn't happen all the time. Anybody else have this problem? Can anybody point to a cause/fix?
RE: Problems ending out of an AutoCAD dwg.
