Sheetmetal Flatten
Sheetmetal Flatten
Hi Folks,
Does anyone know how to flatten this impeller blade, created using the 'project geometry' from the main backplate of the impeller body.
The curves in the backplate were generated with the 'spline' command (has to be on this occasion)
I sometimes use circles,lines & arc commands for generating the blade, and they flatten out ok, but using spline doesnt seem to work. Any ideas appreciated.
RE: Sheetmetal Flatten
As constructed this part will not flatten.
I thought that using the offset would make this a constant thickness.
Shapes generated from lines,arcs, circles generally will flatten out, but not a spline.
