Drawing Export Macro
I am trying to write a macro that will help speed up the process of constantly saving drawings as dxf's for the machine shop. Here is what I have so far:
Dim swApp As SldWorks.SldWorks
Dim Part As SldWorks.ModelDoc2
Dim CPM As SldWorks.CustomPropertyManager
Sub main()
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
Set CPM = Part.Extension.CustomPropertyManager("")
Dim FilePath As String
Dim PathSize As Long
Dim PathNoExtension As String
Dim NewFilePath As String
Dim MyRevVal As String
Dim MyRevValEvaluated As String
CPM.Get2 "Revision", MyRevVal, MyRevValEvaluated
FilePath = Part.GetPathName & Revision
PathSize = Strings.Len(FilePath)
PathNoExtension = Strings.Left(FilePath, PathSize - 6)
NewFilePath = PathNoExtension & MyRevValEvaluated & "dxf"
Part.SaveAs2 NewFilePath, 0, True, False
MsgBox "File Exported " & NewFilePath
End Sub
I have two problems.
1) It exports the file as "filename.RevDXF
File name being the drawing's name and the revision being the custom property value.  Obviously the "." needs to be 3 characters over to the right.
2) The macro gives the dxf the revision of the drawing file, not the part.  When we rev a part, we update the revision of the part file, not the drawing.  I would like the macro to get the revision from the part file or one of the drawing views.
Any help is greatly appreciated.
RE: Drawing Export Macro
CODE
PathNoExtension = Strings.Left(FilePath, PathSize - 7)
NewFilePath = PathNoExtension & MyRevValEvaluated & ".dxf"
batHonesty may be the best policy, but insanity is a better defense.bat
http://www.EsoxRepublic.com-SolidWorks API VB programming help
To obtain the custom properties of the model shown in the drawing, you have to first have your macro figure out what model is shown in the drawing.  You can then get the custom property manager for that ModelDoc2 and get the revision custom property from that.  Here's a sample macro that will look at a drawing and get the referenced document.  The While loop is necessary because the first view or two of a drawing document are not actually model views, they are the sheet format etc, which do not have referenced documents.  GetNextView will return the next view of the document until it gets to the last view, at which point it will return Nothing.  This code will stop at the first view it finds that has a referenced document.  Of course, if your drawing file references multiple different parts/assemblies (even if they are on different sheets), you will have to dig a little deeper.
CODE
Dim swDoc As SldWorks.DrawingDoc
Dim swView As SldWorks.View
Dim myRefDoc As SldWorks.ModelDoc2
Sub main()
If swApp.ActiveDoc.GetType <> swDocDRAWING Then
    MsgBox "Not a drawing"
    Exit Sub
End If
Set swDoc = swApp.ActiveDoc
Set swView = swDoc.GetFirstView
While (Not (swView Is Nothing)) And (myRefDoc Is Nothing)
    If swView.ReferencedDocument Is Nothing Then
        Set swView = swView.GetNextView
    Else
        Set myRefDoc = swView.ReferencedDocument
    End If
Wend
If myRefDoc Is Nothing Then
    MsgBox "No referenced document found."
Else
    MsgBox "Referenced document: " & myRefDoc.GetPathName
End If
End Sub
Thanks for the help.  I think I should be able to take it from here.
