Moving Part/Assy files around.
Is there a way of moving a part file from one location to another without the Assy falling over? I don't use PDM works, so it is all filing is done in Windows.
Paul.
Paul.
RE: Moving Part/Assy files around.
After a file is moved, you can open the part first before opening the assembly. When the assembly is saved it will point to the new location.
You can use SW Explorer to change references.
If a SW fails to find a file on its own, it will prompt. Again, when the assembly is saved it will point to the new location.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
BTW - there is "The Tick" on www.omegaowners.com too.
You can also move the file using windows and prior to opening the SolidWorks assembly (do a single left click), click on references (in the lower right corner of the open dialog) and browse for the moved file in question.
There is no automatic way for solidworks to find a file that has been moved.
-Dustin
Professional Engineer
Certified SolidWorks Professional
you can use SWExplorer to copy a file and it will carry the assembly links over to the new part. You will still have to delete the old part. Tinker with it, as I recall, it is a little quirky.
-Dustin
