Hatch turned off...how do I get it back?
If you go to the hatch properties and change it to "none", how do you get it back?
RE: Hatch turned off...how do I get it back?
You can search for Area Fill's via the Edit Search function.  Then you can get to the properties by using Alt-Enter.  If you have multiple area fills on the drawing, click-drag an area around the one in question first.  Then key in the following in your power command window:
T:Area Fill, sel
This will do an EDIT, SEARCH, TYPE Area Fill within the current selection.
I couldn't get either to work, then I realized its not an "Area Fill"...hatching is a "Generated Shape".
The power command you mentioned didn't seem to work, because there was no hatch highlighted/selected to right mouse click and change the properties.  However, with the edit/search, I was able to find the missing hatch and turn it back on.
