Units,tapered rectangle section,material constants in STAAD
I have some questions in STAAD, it will be appreciated if someone helps me.
1.    How to change the units to SI (kN, m, c) in the concrete design check module (in choosing the design brief).
2.    How to make a tapered rectangle section.
3.    How to make a star shaped angles.
4.    How to change the material constants like the density, poisson ratio,...etc using a menu option in the graphical user interface not by editing the command input file.
