Help needed for "select edges normal to surface"-macro
I'm trying to build a macro that can select edges normal to a preselected face. For instance if you have a rectangular plate, and want's to chamfer the corners, I would be able to selecet all 'corner-edges', just by selecting one face.
I can get boundary faces with .GetEdges, but I can't figure out how to select normal edges.
I'm trying to make a macro, because I can't find any methode for this selection via the standard GUI. So if anyone knows a simple way of selecting 'normal-edges' without help from a macro, I'm interested in that too.
RE: Help needed for "select edges normal to surface"-macro
I've also tried simply select all edges, and then deselct edges who are not parallel to the surface normal. But same story - can't determind the direction of an edge.
Mayby there is a parallel-methode??? Then I could just preselect an edge, and then the macro could find all remaining edges parallel to that one???
I ended up with preselecting an edge, and then find all other edges in that direction. It only works on edges in x/y/z direction(what I needed), but could easily be modified to edges running parralel in the same plane as the preselected.
Here is the code. Raw, unpolished, with danish comments and without errorhandling etc.
' Selects all edges with same direction as the preselected one
' (works only in x/y/z direction)
Option Explicit
Sub main()
Dim swApp As SldWorks.SldWorks
Dim swModel As SldWorks.ModelDoc2
Dim swSelMgr As SldWorks.SelectionMgr
Dim vEdgeArr As Variant
Dim vEdge As Variant
Dim swEdge As SldWorks.Edge
Dim vCurveParam As Variant
Dim dirOK, dir1 As Variant
Dim dirVek(2) As Variant
Dim Bodyarr As Variant
Dim Body As SldWorks.Body2
Dim Edgearr As Variant
Dim EdgeGood(10) As SldWorks.Edge
Dim bRet As Boolean
Dim swSelData As SldWorks.SelectData
Set swApp = Application.SldWorks
Set swModel = swApp.ActiveDoc
Set swSelMgr = swModel.SelectionManager
'Find den ønskede kant-retning
Set swEdge = swSelMgr.GetSelectedObject5(1)
vCurveParam = swEdge.GetCurveParams2
dirVek(0) = Round(vCurveParam(0) - vCurveParam(3), 10) ' afrundes da der er kans på 17 decimal!
dirVek(1) = Round(vCurveParam(1) - vCurveParam(4), 10)
dirVek(2) = Round(vCurveParam(2) - vCurveParam(5), 10)
If dirVek(0) = 0 And dirVek(1) = 0 And dirVek(2) <> 0 Then
dirOK = 1 'Z
ElseIf dirVek(0) = 0 And dirVek(1) <> 0 And dirVek(2) = 0 Then
dirOK = 2 'Y
ElseIf dirVek(0) <> 0 And dirVek(1) = 0 And dirVek(2) = 0 Then
dirOK = 3 'X
Else
MsgBox ("Kun kanter der løber i x/y/z retning er supporteret :)")
End
End If
swModel.ClearSelection2 True
Bodyarr = swModel.GetBodies2(swSolidBody, True)
Set Body = Bodyarr(0)
Edgearr = Body.GetEdges
For Each vEdge In Edgearr
'swEdge.Display 2, 0#, 0#, 0#, True ' debuging
Set swEdge = vEdge
'swEdge.Display 2, 1#, 1#, 0#, True ' debuging
dir1 = 1 'Z
dir1 = 2 'Y
dir1 = 3 'X
Else
dir1 = 0
End If
If dir1 = dirOK Then
bRet = swEdge.Select4(True, swSelData): Debug.Assert bRet
End If
CODE
Dim swDoc As SldWorks.ModelDoc2
Dim myMathUtil As SldWorks.MathUtility
Dim myFaceNormal As MathVector
Dim myFace As SldWorks.Face2
Dim myEdge As SldWorks.Edge
Dim myCurve As SldWorks.Curve
Dim myDirVec As SldWorks.MathVector
Dim myLoop As SldWorks.Loop2
Dim myVertices As Variant
Dim myEdges As Variant
Dim myParams As Variant
Dim myXYZ(2) As Double
Dim myCrossValue As Double
Dim myCrossVector As MathVector
Dim myFaceColl As New Collection
Dim h As Long
Dim i As Long
Dim j As Long
Sub main()
Set swDoc = swApp.ActiveDoc
Set myMathUtil = swApp.GetMathUtility
Set swSelMgr = swDoc.SelectionManager
'''''''''Quit if not a part doc
If swDoc.GetType <> swDocPART Then
MsgBox "This macro works on parts only!"
Set swApp = Nothing
Set swDoc = Nothing
Exit Sub
End If
'''''''Get a collection of currently selected faces
For i = 1 To swSelMgr.GetSelectedObjectCount2(-1)
'''''''only add faces to collection
If swSelMgr.GetSelectedObjectType3(i, -1) = swSelFACES Then
Set myFace = swSelMgr.GetSelectedObject6(i, -1)
''''''Only add face if planar. Non-planar faces have 0,0,0 normal.
If myMathUtil.CreateVector(myFace.Normal).GetLength <> 0 Then
myFaceColl.Add myFace
End If
End If
Next i
swDoc.ClearSelection2 True
'''''''iterate through face collection
For Each myFace In myFaceColl
''''Create vector for face normal
Set myFaceNormal = myMathUtil.CreateVector(myFace.Normal)
''''Get first loop of face
Set myLoop = myFace.GetFirstLoop
While Not myLoop Is Nothing
'''''Get all vertices in loop
myVertices = myLoop.GetVertices
For i = 0 To UBound(myVertices)
''''Get all edges owned by vertex
myEdges = myVertices(i).GetEdges
For j = 0 To UBound(myEdges)
Set myEdge = myEdges(j)
Set myCurve = myEdge.GetCurve
If 0 = myCurve.IsLine Then
'not a line, do nothing
Else
myParams = myCurve.LineParams
'last 3 elements are the direction unit vector
myXYZ(0) = myParams(3)
myXYZ(1) = myParams(4)
myXYZ(2) = myParams(5)
Set myDirVec = myMathUtil.CreateVector(myXYZ)
Set myCrossVector = myDirVec.Cross(myFaceNormal)
If myCrossVector.GetLength < 0.00000000001 Then
'if cross product is zero, select edge
myEdge.Select4 True, Nothing
End If
End If
Next j
Next i
Set myLoop = myLoop.GetNext
Wend
Next myFace
Set swApp = Nothing
Set swDoc = Nothing
Set swSelMgr = Nothing
Set myFaceColl = Nothing
End Sub
With this code, you can select any combination of faces, edges, features, etc. before running the code. After running, all edges adjacent and normal to the faces selected will be selected. In pseudocode, the procedure is:
Examine selections, add selected faces to new collection (if planar)
For each face:
Find the face normal vector
Get array of vertexes in the loop
For each vertex in the loop:
Get array of edges
For each edge:
Get edge's Curve object
Check if linear
Create direction vector
Cross vector with normal vector
If vector length is 0, select edge
Nice to know that such usefull help is available at this site!
