curved washer
curved washer
Hi all
I can wrap geometry onto a curved surface or extrusion. How can I cut and leave the wrapped sketch?
RE: curved washer
If you explain what you are trying to achieve, we may be able to give a better answer.
RE: curved washer
I am trying to model basically a curved or bowed washer. (a flat washer formed into an arc to act as a spring) Ive extruded the partial arc and were trying to use warap to get the form I need, but cannot trim sections outside of the form.
RE: curved washer
RE: curved washer
I'll have to play with it as I dont use sheet metal tools much. Ill research what I can and any tips would be great.
RE: curved washer
Dan
www.eltronresearch.com
RE: curved washer
RE: curved washer
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
