Drawings slow: BOM editing, Regen. Practical limit to pages,views?
What should have taken 1 hour took 5 hrs this morning.
It takes 1-5 minutes to edit 1 cell in BOM, or regen, or save.
I have a dwg with 9,000 kb model size, dwg is 18,000 kb.
11 sheets of 11x17 size paper
Each sheet has 2-6 views/details on it.
I have Auto view update unchecked.
Also have gone through options to select faster options.
Is there a practical limit to the size of model, or number of sheets, or number of views that SW can effectively manage on 1 assembly drawing?
Thank you
ProjEng99
XP Pro 2002 SP2
2.8 GHZ DUAL CORE PENTIUM
3G RAM
80G DRIVE
ATI FIREGL V3300
Thank you
ProjEng99
XP Pro 2002 SP2
3G RAM
80G DRIVE
ATI FIREGL V3300
RE: Drawings slow: BOM editing, Regen. Practical limit to pages,views?
Which version of SW and SP?
Are you running an anti-virus which is checking every file? If so set it to ignore SW files.
How much RAM and VM is being used? (check the Task Manager)
Are you using the /3GB switch?
What other processes are running?
Are you working over a network?
Do you have Windows Desktop Search running?
Do you have Dissection running?
Anti-virus: only a scheduled scan once a wk.
RAM used: 584MB used w/o SW, 1G used w/SW
3GB switch: no, have heard of it, how to turn on?
No other apps, 38 processes but no hogs to shut down I know of.
Network: no, but backups are saved to server
Desktop search: yes. I shut it down and this helped some!
Dissection: what's this?
Thank you
It can be disabled at Tools > Options > System Options > Search.
Both Windows Desktop Search and Dissection will slow SW to a crawl.
Dissection was off.
Thank you it is significantly better, any other tips bring 'em.
thread559-155411: 3GB Memory Switch..
